VrayLight Bug by setting Velocity pass
  • VrayLight Bug by setting Velocity pass
    When creating VrayRectLight which set texure of image sequence and setting velocity pass by default attribute, A render result is strange.
    Texture result is collapsed.
    I tested by texure format EXR and JPG.
    Could you please attach an example scene and an output image with the issue?
    Zdravko Keremidchiev
      I attached example scene.
      Correct image.
      InCorrect image.
      Velocity pass is ON.
      This scene created by Ramp texture animation.
      Moreover, this brought the right result by Motion blur ON also by the case of Velocity pass ON.
      However, this is not the purpose.
        Thank you for the scene; I can reproduce the issue here and it will be fixed.
          Will be fixed after revision 17670
          V-Ray/PhoenixFD for Maya developer
